9 members (Phak1, Bill Hanlon, Rusty Rod, TUTS 59, Napco Man, Cosmo, ndkid275, 2 invisible),
57
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 56 | I'm back. I've got my horn to work as orginally designed with ground circuit in stering column. My problem is when I begin to turn wheel the contact spring/bushing under horn contact plate slides off the brass hub below it. I've seen plastic housed horn contact bushing, is this the fix? My original spring contact thing keeps jumping off brass hub, and horn goes off.
Bruce | | |
