7 members (wilbur53, stlcardinalsguy, Wally / Montana, King Kielbasa, joe apple, Hotrod Lincoln, Otto Skorzeny),
105
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Bryan, do you mean that the one you bought and painted was 1 inch shorter than the one you took off? Or do you mean it was shorter than the one on the other side? Was this an original or a repro? Fiberglass or metal? Go ahead and measure but tell me from where to where. The conventional wisdom here on the Bolt is that 1/2 ton AD pickups and suburban/panels share the same running board. I hope your experience was a one time thing. How did you correct the problem?
Weeds | | |
