8 members (Swami29, Otto Skorzeny, cmayna, tclederman, klhansen, KEVINSKI, StevenO, 55shaker),
122
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,114 Posts1,056,605 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | The BB is positioned at 5 degrees before TDC on a 216 flywheel and 2 degrees after on a later 235 which alone may be enough difference to make it not want to fire. Secondly the BB shows up in the window both when #1 is at TDC and also #6 so being 180 degrees out is also a possibility. Try this procedure to set timing for startup: http://speedprint.com/deves50/doc/enginetiming.pdf
1952 1300 Canadian 1/2 ton restomod You Tube | | | |
Entire Thread
235 engine, long nap, trying to wake it up.(long)
| vintage_car | 08/17/2010 4:12 PM |
Re: 235 engine, long nap, trying to wake it up.(long)
| JiMerit Boltr#43 | 08/17/2010 6:58 PM |
| vintage_car | 08/17/2010 7:30 PM |
| JiMerit Boltr#43 | 08/17/2010 7:42 PM |
| vintage_car | 08/17/2010 8:14 PM |
| vintage_car | 08/17/2010 8:16 PM |
| Curt B. | 08/17/2010 9:24 PM |
| 53moneypit | 08/17/2010 9:50 PM |
| vintage_car | 08/17/2010 10:04 PM |
| chicklin | 08/18/2010 2:57 AM | |
