| | | Forums66 Topics128,021 Posts1,055,348 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 3 caps = 6v battery Yes, it could be a bad ground but it could also be a variety of other things. Have you checked/set the points and plugs? Has this truck sat idle for a while? If yes, have you drained out the old gas and do the ignition wires (spark plug wires) look good (or are they cracked and brittle)? | | |
