8 members (2-Ton, DadsFirstPickup, 32Fordpuchoptop, FAST55, Otto Skorzeny, mason86, rfs56trk, TexasJim50),
73
2
Mod | | | Forums66 Topics128,049 Posts1,055,661 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66924 10/08/2006 6:25 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Racecarl,
I don't know how much initial advance the mark yields. In this case one would have to rely on performance rather than a "number".
I think if you advance your timing enough you will get preignition or ping.
There are two indicator of excessive advance..increased operating temperature and/or pinging.
You should be able to use one, or both to set your timing to the safest maximum setting for best engine performance.
Stuart | | |
