8 members (Oldcaliforniakid, Otto Skorzeny, jmoore, frogfarmer, Hotrod Lincoln, 49nut, Stovebolt48, mason86), 114 guests, and 0 robots.
Topics128,050
Posts1,055,671
#66922 10/08/2006 3:18 AM
Does anyone know how much initial advance setting the timing to the ball on the flywheel yields?
When I got my 261 running I was very careful to set the timing exactly 'on the ball'. I also went to great pains to tighten the distributor down exactly in the center of the 'octane scale'.
My 51 Chevy 1/2 ton with 89mm (.70) overdrive and 3.50 rear gears gets about 14 mpg on the highway. I have about 1000 miles on a complete overhaul (.030 overbore, split exhaust, single Carter YF, 848 head).
Today just for giggles I advanced the timing to the last of the marks on the advance side of the scale. It seems like the throttle is more responsive and I don't have to push the gas pedal as far to maintain road speed. I can't get this engine to ping so I don't feel the timing is too far advanced. I will be getting a vaccuum gauge on the engine (as soon as I find it) to verify the timing settings.
The flywheel I am using came from a 235 truck engine if that makes a difference.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
#66923 10/08/2006 4:29 AM
You probably won't get it to ping, the first indication of over advance would be the engine kicking back against the starter in that case. Today's fuels need a lot more advance than is noted in the manuals for best performance.
#66924 10/08/2006 6:25 AM
Racecarl,
I don't know how much initial advance the mark yields. In this case one would have to rely on performance rather than a "number".
I think if you advance your timing enough you will get preignition or ping.
There are two indicator of excessive advance..increased operating temperature and/or pinging.
You should be able to use one, or both to set your timing to the safest maximum setting for best engine performance.
Stuart
