1 members (Hotrod Lincoln),
104
2
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#66883 10/08/2006 11:17 PM | Joined: Nov 2004 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 39 | 1948 chevy 1/2 ton with my '48 I had this problem and it was the ring gear was worn out... my cheapskate brother told me of how you could simply turn the ring gear around (with slight modifications) and we did and it worked perfect... I had to heat the flywheel in my wife's oven (might suggest an option to that) but it was hard to get back on but heat did the trick... no more loud grinding noise every other time... | | |
