| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | I welded on some cab corners, and needed to fill the seam, between the door and cab, to make it the same gap all the way down. I used evercoat rage extreme filler on bare metal. The thickest part ended up being about 1/2 inch by 1/2 inch, which is thicker than I'm comfortable with usually. Just wandering if you guys think this will last. http://pic20.picturetrail.com/VOL1268/5055721/20931166/390180677.jpg http://pic20.picturetrail.com/VOL1268/5055721/20931166/390180698.jpg
In the Gallery[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
