Where is it binding? Gonna get simple here, no offense intended, but are the piston and pad fully pushed back? Or is the caliper not fitting into the backing-plate mount? (see above about grinding.)
They will go on, just might need some help.
Good luck.
Current fleet (subject to change w/o notice)
\'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run.
My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787.
Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
