motor sits too low to run a mech fan and rad too close to waterpump pully.
Would moving the auto trans cooler (with it's own small fan) out from in front of the rad (off to the side?)so a pusher could be installed on the bottom half of rad be a solution( the current puller is on the top half of rad)?
But then I'd have 3 fans running.. would there be an issue with that i may not have thought of?
