| | | Forums66 Topics128,007 Posts1,055,275 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | If it's going to sit a long time I would pull the plugs and squirt some oil into the cylinders and rotate the crank by hand to oil wipe the cylinder walls. You can rotate it every once in a while too. There are also engine bags available if you want to seal it from dust and dirt.
Drew
