| | | Forums66 Topics128,172 Posts1,057,108 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | If you are not afraid of a little asbestos, there is nothing wrong with them. They are actually not as hard on the drums as new ones. Drums that have had the old linings can easily be turned. Drums with modern linings usually have to be turned and then the hot spots ground out and then trued. I have a setup to do this, but very few people are equipped to grind hot spots. This is why turning truck drums has become a thing of the past. The new non asbestos linings also require more pedal effort. | | |
