3 members (Barnfind49, kades51, 1 invisible),
67
2
Mod | | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yes as larry says you can, use the ignition switch for your terminations, just lay it on the seat on something and use the key if you want. Shut it off from inside the cab. Disconnect the battery before you go in the house though. No you don't need any gauges.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
