1 members (baldeagle),
46
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 71 | I have an aftermarket timing gear cover with timing tabs on a small block Chevy. I know I have the cam timing dialed in but now I'm worried the TDC marker on the harmonic balancer may not be in sync with timing tab since some engines had tabs positioned differently. Anyone got a trick for finding TDC on number one cylinder on a motor already installed? I have a dial indicator but getting it to read through the plug hole to the top of the piston is going to be a problem. | | |
