| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 18 New Guy | | New Guy Joined: Feb 2004 Posts: 18 | thanks. Last night while laying in bed i figured that might be the case the case. I think I'd rather run my orig. caps than an o-ring.
Both the intake and exhaust valves have a single groove in them. My head had orig valves that were marked '41.
It is worth noting that the replacement valves are flat top (which would increase compression slightly) and a few mm longer with the keepers set a few mm off from the orig design.
Had i realized that the cam gear was fiber i would have never made these discoveries. | | |
