You can also get oil in the solenoid that can cause the relay to act up or blow a fuse in the system. You can replace the seal and also take the solenoid apart and wash it out with cleaning solvent. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes
1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes
2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans
1947 Willys CJ2A w/F-Head engine
