| | | Forums66 Topics128,026 Posts1,055,409 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | I'm getting a clicking noise (sounds like it comes from firewall area where OD relay is positioned) at around 25 mph - Goes away above and below the normal od engage speed, and it makes the noise whether it's in or out of overdrive. Tried new relay, still makes the clicking sound. I've been told the governor seldom goes out and that it's probably still a relay problem - any thoughts?? Dale | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The relay will click once when the vehicle hits around 25 to 28 mph. If it clicks more than once I would suspect faulty wiring to the governor or oily switch in the governor. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | You can also get oil in the solenoid that can cause the relay to act up or blow a fuse in the system. You can replace the seal and also take the solenoid apart and wash it out with cleaning solvent. Fred
| | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | Thanks! I will try the cleaning you mentioned and do see oil deposits - so --- maybe that will help. Will let you know -- thanks again -- Dale | | |
