| | | Forums66 Topics128,066 Posts1,055,876 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | I have a '62 w/stroked 350. The only headers that fit well for me were block huggers. Lots of manufacurers make the block huggers for SBC. Mine are Patriot from Summit. Suggest you may want to also consider some flexible pipe connections from Summit to take off some of the pressure off the headers. But, I was using a saddle front motor mounnt. If you have side motor mounts, then I am not sure if the block huggers will clear the motor mounts. Someone else can answer that I'm sure. | | |
