| | | Forums66 Topics128,071 Posts1,055,901 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 10 New Guy | | New Guy Joined: May 2010 Posts: 10 | Does anyone know who makes headers for a 1962 Chevy with a 350 engine in it? Remember this has the torsion bar front end so its kinda tricky. | | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | I have a '62 w/stroked 350. The only headers that fit well for me were block huggers. Lots of manufacurers make the block huggers for SBC. Mine are Patriot from Summit. Suggest you may want to also consider some flexible pipe connections from Summit to take off some of the pressure off the headers. But, I was using a saddle front motor mounnt. If you have side motor mounts, then I am not sure if the block huggers will clear the motor mounts. Someone else can answer that I'm sure. | | |
