| | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | 60-61-62 came with a hydraulic clutch actuator mounted on the bellhousing. You will need a V-8 bellhousing from one of those three years. You will also need a V-8 flywheel. The clutch can possibly be used if it is the same size as the V-8 flywheel you obtain (either 10" or 11"). The rear mounts on the bellhousing/crossmember are the same but nothing from the 235 will interchange with the V-8. Try to find the stock front or side mounts from a V-8 truck otherwise there are some aftermarket mount kits. Fred
1956 3100 Pickup/Red/350/3sp OD/PS/Disc Brakes 1957 Bel Air Sport Coupe/Red/355/TH350/PS/Disc Brakes 2017 Silverado LT Single Cab SB/Black/5.3/6 Speed Trans 1947 Willys CJ2A w/F-Head engine
