0 members (),
127
2
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | You are going to have to get a drive shaft built with a slip joint. If its a swb pickup, you can get by with a single Drive shaft. I am assuming the 8.8 came out of a 56 or earlier. 57 came out with the 9". Some of them used Spicer 1310 and some used a Mechanics joint. If you have the Ford drive shaft, measure from the middle of the companion flange on the rear to the middle of the companion flange on the rear. You might want to take the companion flange off the transmission and take it to a drife shaft shop. Tell them what you are doing and have them build them a shaft with a slip joint. | | |
