As most of the others have said, if you want to do this on your own, try and remember to do the flushing in reverse. From the bottom up. Helps to break out any of the larger scales. And also try and use as hot as water as you can get. Strong detergent seemed to do the best for my task, but I did use some LimeAway added to the mix. So far...not troubles.
dj durant
More pix on Flickr
