| | | Forums66 Topics128,035 Posts1,055,566 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The oil pan has to come off, too. There's 2 bolts for the timing cover that go in from inside the pan (I know, crazy isn't it?) You'll be looking at removing the radiator and the grille at least to pull the cam. It's pressed, so a trip to the machine shop may be necessary. This is assuming it's just the gear and not a broken cam.
Bill Burmeister | | |
