A good safe way to pull that engine is go to Ace hardware or some place like that and get two eye bolts the same size as your head bolts and take two head bolts out and replace with them with them thats the way I have been duing it I also built a chain spaner above the engine out of a pc.of 1 1/2 angle iron it will keep the engine in control and the eye bolts are rated at around 1200 pounds each so it is real safe.
Pete
