4 members (UtahYork, Donf, 46 Texaco, 1 invisible),
107
2
Mod | | | Forums66 Topics128,115 Posts1,056,633 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | One tablespoon of carbon buildup on top of a piston will raise the compression about half a ratio, but it won't be consistent from one cylinder to another. The carbon deposits can also glow red hot and promote pre-ignition and detonation on a hard pull. Take an air die grinder or even a high-speed electric drill motor and a fine-bristle wire brush and buff off as much carbon as you can. Just be sure to blow the residue away with lots of compressed air after you finish cleaning. Jerry
