A 216 and the low pressure 235 will have the tall side cover that surrounds the spark plugs.
Also the rocker arm cover will only have 2 studs through the top rather than 4 screws on the sides. A full pressure 235 is a bolt in replacement. Check Patrick's in the links page, there is more information on id for the early235 there.
Bill Burmeister
