| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Just like truckernix points out, if there is no restriction at the filter or any of the lines between the "T" that leads to your gauge and the opening to the crankcase you will show low pressure.
I suppose there could be a restriction in one of the fittings like the one in the pipe leading to the rocker arm & shaft area.
truckernix where is the one in your filter and what does it look like?
