7 members (SmalltownTRKGuy, 52Carl, Ponchogl, GradyB, Otto Skorzeny, GRNHydra, 1 invisible),
76
0
Mod | | | Forums66 Topics128,080 Posts1,055,945 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 25 Apprentice | | Apprentice Joined: Nov 2009 Posts: 25 | Hello. I have a problem that has got me stumped once again on my 235. When i start the engine completely cold, I get about 30-35 pounds of pressure. Rockers are oiling great. Now as the engine warms up and runs for awhile at idle, I start to loose pressure. It eventually drops to about 10 pounds but im still getting oil to the rockers but not as much. Here is some info that im using.
58 block 54 head Brand new oil pump external oil filter mounted on intake. Running 10-30 oil.
Any ideas or help would be great. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | There may be other reason but I'd look at main bearings first. Some of the guys here are more knowledgable than I so keep checking this posting. And hey...WELCOME! to the best site on the net for old Chevy trucks. Nice ot have you aboard. | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Drop the oil pan and check the condition of the rod and main bearings. It's not uncommon for a cold engine to have good oil pressure, and then it drops a lot once the oil and the parts warm up. If the crankshaft isn't worn excessively or out of round, changing the worn bearings will bring the pressure back up to normal. Anything over about 2 1/2 to 3 thousandths of clearance on any bearing is excessive. 1 1/2 thousandths is better. 10W-30 oil stays at the 10 weight thickness all the time- - - -it just lubricates like a 30 weight when it's hot. Switching to a physically thicker oil like a 20W-50 or a 15W40, or even straight 30 weight will help keep the pressure from dropping to dangerous levels until you get a more permanent fix done. Jerry
| | | | | Joined: Nov 2009 Posts: 25 Apprentice | | Apprentice Joined: Nov 2009 Posts: 25 | Thanks 53moneypit and Hotrod Lincoln for the quick replies. This engine was just put together. All new bearings. I was wondering about the oil. I may try the straight 30 weight. Any other ideas? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Was the crankshaft reground before you put in the all new bearings?
How did you determine what size bearings to put in?
| | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | New bearings should hold pressure better than that- - - - - -I'd suggest making sure they're the right size. If you've got standard-diameter bearings on a .010" undersize shaft, for instance, the pressure will drop radically as the engine warms up. Have you put any road miles on it yet? A mismatch on rod or main bearing sizes will produce some nasty knocks as soon as road load is into the mix. Jerry
| | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | I thought pressure drop hot to 10-15 was normal on a 235.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Not on an insert-bearing 235. The splash-oil engines ran fine on pressure that low, but that's on the dangerously low side for a fresh full-pressure engine. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I am wondering about the oil filter. If it is a bypass setup, I would suggest removing the input feed, inserting a plug and testing the engine again. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | What truckernix said.
If the gauge is between the pressure port on the block and the filter you are only measuring how dirty your filter is. The return line from the filter to the block just dumps into the crank case so the only resistance in the lines to cause a pressure reading on the gauge is the filter itself, the dirtier it is the more pressure you will read.
Cap or plug any of the lines between the point where the gauge line comes off and where the filter return line reattaches to the block. Now your gauge is on a dead-end line and will show the pressure that your bearings are seeing.
| | | | | Joined: Nov 2009 Posts: 25 Apprentice | | Apprentice Joined: Nov 2009 Posts: 25 | Kip41, I have a T on the pressure port with one side for the gauge and the other feeds the oil filter. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My concern is that maybe you have an oil filter rig that had an external restriction which is missing. My oil filter has a built in restriction in the inner pipe. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Just like truckernix points out, if there is no restriction at the filter or any of the lines between the "T" that leads to your gauge and the opening to the crankcase you will show low pressure.
I suppose there could be a restriction in one of the fittings like the one in the pipe leading to the rocker arm & shaft area.
truckernix where is the one in your filter and what does it look like?
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The restriction in my filter assembly is a very small hole in the inner tube about an inch from the top. The return is at the bottom of the tube. The hole I would guess is smaller than 1/16".
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I just measured mine, comes out to approximatly .060".
Bill Burmeister | | |
