1 members (baldeagle),
30
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61542 06/09/2006 2:47 PM | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | I had to remove the Manifolds over the weekend to replace a broken exhaust stud. The tail pipe wasn’t connected properly and all the exhaust was going into the cab, I also replaced the thermostat for the hell of it.
Anyhow I was running the engine to warm it up (with out the radiator cap) and now that the tail pipe to flange is sealed I notice a little smoke coming out of the valve cover oil filler cap. It wasn’t a lot but it was enough to notice it faintly in the sun light glare.
What causes this? Excessive gas vapors? Or is this normal? New manifold gasket?
Thanks Billy | | |
