| | | Forums66 Topics128,042 Posts1,055,516 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not until you ask what AD stands for, every newbie has to ask that. Try a Google search and you can choose from hundreds of suppliers. All you have to be careful of is that you still have full engagement of the nuts with the spacer in place. If not then you will need to replace the studs with longer ones. Here is one to start you off; http://www.ezaccessory.com/Wheel_Spacers_s/27.htm DG
Denny G Sandwich, IL
