| | | Forums66 Topics128,077 Posts1,055,932 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 54 3100
. . original (to the truck) 4 speed transmission . . - torque-tube rear-end and SM420 with u-joint cover?
. . if I used a 55 - 62 truck 4 speed transmission . . - open driveshaft with open u-joint (SM420)?
Both of the above have a u-joint yoke that is bolted to the transmission and the other u-joint yoke slides on the driveshaft spline.
. . The rear-end has a fixed pinion yoke and the rear of the transmission has a fixed yoke, so "where is the slip yoke"? . . - what transmission and rear end (drive shaft?) are you referring to? Maybe a few photos might be helpful.
All 1954 3100 Chevrolet trucks are "short bed" (and "step side", for that matter). Why would a two piece driveshaft be needed?
I know nothing about drive-shafts, but the people posting above are very knowledgeable. With more information about the transmission and rear end, you will get the best answers possible.
