1 members (Shade Baby),
21
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | If the transmission is the one that came in the truck it would be a Clark 267V which was a relatively fast first and reverse gear and close ratio between 4th and 5th. It was made to split the first 3 gears then go from 4th low axle to 5th low axle and then back to 4th high axle and then 5th high axle. It was what was commonly referred to as a working 5th. | | |
