| | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#60433 05/14/2006 4:37 PM | Joined: Jun 2000 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2000 Posts: 50 | Joe - Thanks for clearing this up for me. Looking at the old 139 tooth starter gear along the starter shaft axis the teeth appear to be cut much straighter and more of a pyramid shape than the new starter for the 168 tooth flywheel which appears to curve at the ends as if it is designed to "screw" into the teeth as the starter is engaged...this also clears up what I thought was a mistake on the NAPA site. For anyone interested I found this interesting web site that lists many OEM part numbers for with dimensions for flywheel ring gears. www.ringgearindia.com/docs/products.asp Thanks agian - Bug
1951 Chevrolet 3100 AD Pickup
