0 members (),
128
2
Mod | | | Forums66 Topics128,167 Posts1,057,021 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | What condition are the spark plug wires in? I had one that would idle fine, run okay under light load, but would spit, sputter and everything else and decided for grins and giggles to replace the plug wires. Ran ike a champ after that.
Check the dwell on those points to see if the dwell is good at idle only to go bad as the engine speed goes up. The dwell will tell you alot. Make sure that during all the testing that your points didn't get burnt.
Sounds ignition related to me. If you have another distributor available I would try it.
Only other thing I can think of has been covered by you trying a different carb and having the same results.
Entire Thread
About at my wits end, getting an engine to run
| Powerwagontim | 12/10/2009 5:11 AM |
Re: About at my wits end, getting an engine to run
| MikeE | 12/10/2009 5:21 AM |
| Mikestem | 12/10/2009 5:55 AM |
| 3B | 12/10/2009 6:33 AM |
| glasman | 12/10/2009 1:05 PM |
| Daniel Bland | 12/10/2009 1:07 PM |
| Powerwagontim | 12/10/2009 1:13 PM |
| Hotrod Lincoln | 12/10/2009 1:50 PM |
| Builder | 12/10/2009 2:37 PM |
| 3B | 12/10/2009 5:03 PM |
| Justhorsenround | 12/10/2009 6:40 PM |
| Harvester | 12/10/2009 6:41 PM |
| Builder | 12/10/2009 10:02 PM |
| 61nate | 12/12/2009 12:35 AM |
| Powerwagontim | 12/12/2009 3:20 AM |
| Tomcoe | 12/12/2009 6:01 AM |
| Tomcoe | 12/12/2009 6:12 AM |
| Mike B | 12/12/2009 11:37 AM |
| crenwelge | 12/12/2009 6:54 PM |
| Wrenchbender Ret. | 12/13/2009 12:32 AM |
| Hotrod Lincoln | 12/13/2009 3:15 AM |
| crenwelge | 12/13/2009 5:08 AM |
| Wrenchbender Ret. | 12/13/2009 4:01 PM |
| 65 WonTon | 12/13/2009 5:56 AM |
| glasman | 12/13/2009 4:06 PM |
| crenwelge | 12/13/2009 6:17 PM |
| Spareparts2 | 12/13/2009 7:02 PM |
| Wrenchbender Ret. | 12/13/2009 11:00 PM |
| Roy Rodgers | 12/13/2009 11:41 PM |
| Builder | 12/14/2009 6:45 AM |
| sask42 | 12/15/2009 5:29 AM |
| PapaJ | 12/15/2009 8:00 AM |
| Powerwagontim | 12/17/2009 1:25 PM |
| Repair | 12/17/2009 3:23 PM |
| Builder | 12/17/2009 9:28 PM |
| Powerwagontim | 12/18/2009 2:44 AM |
| Powerwagontim | 12/18/2009 3:01 AM |
| Tomcoe | 12/18/2009 3:04 AM |
| sask42 | 12/22/2009 1:44 AM |
| to_many_irons | 12/28/2009 9:57 PM |
| PapaJ | 12/29/2009 9:38 AM |
| to_many_irons | 12/30/2009 4:17 AM |
| sask42 | 12/31/2009 5:27 AM | |
