Bryan,
The later boxes mount very different than the 41 - 46. Get the penrite lube. It is a direct replacement for the original lube used in these boxes. It will take hours to pour into the box. It is very thick. The 42 - 46 steering box is the best box for your truck if you want a bolt in, original type solution.
Bill Schickling
1940 1/2 ton, 1940 3/4 ton
My web page
