The springs are the same left to right. You might have to install the rear threaded bolt first so you can wiggle the spring around by hand to get it started. Once they are started, hook up the u-bolts and axle, then work your way forward. Thats how I had to do mine, I tried to install the axle and springs as a unit and ran in to the same problem with the rear bolts.
Joe
