Last night I finally got my transmission put back in but as I laid awake in bed thinking of my progress I began to wonder if I put the clutch in the proper way. Is it possible to put it in backwards? If I did manage to do such, what are the consequences? I am hoping that it does not fit backwards and the more I think of it I am starting to convince myself so as I do not see it fitting against the flywheel if it were in properly. My clutch seems to fit perfectly and it works when I press on the peddle. I really hope I do not need to remove that transmission again!
Also, what type of fluid would I use to fill up my transmission, Just normal manual transmission fluid? How much do I put in, just to the bottom of the fill hole or a measured amount?
