| | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59543 04/24/2006 9:46 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have a 235 in my 52 with next to no clearence. I actually had one blade fly off and land on the crossmember. I was running about 2500 rpm when it happened and it twisted the belt but somewhow did not even scratch the radiator. I was only about 3,000 miles from home at the time. I used a hacksaw to cut the opposing blade off. with a two bladed fan I was able to get to where I could find another old one with no problems. If you keep the setup you have you may want to check your fan for cracks, mine had had one blade cracked through the rivets for a long time apparently. | | |
