Quote
Originally posted by MO 49 3100:
Thanks Guys!!
I just needed some reassurance that it could be done before I devoted alot of time into it.
If the 305 in fuel injected what should I do try and keep it that way or could I get an older intake and stick a carb on it?
You could go either way. Depends on how much extra work you want to do. AND you will do extra work to make the FI work. Fuel return lines, sensors, computers, extra wiring, etc. With a carb, put fuel to it, spark to it and away you go!
Visit my 'burb link below and follow along as I put Tuned Port Fuel Injection in my old Chevy.
