| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58449 03/29/2006 2:35 AM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Mike, They ALL used the rings. Using the rings makes a better job, won't move around and less likely to leak. You can buy these from most truck vendors or make some from exhaust tubing. Also I like to use the Copper Coat gasket sealer for the manifolds. | | |
