Steve, I am with you on the size of brakes. Having smoked the brakes on a few stock chassis, I understand the need for whoa power. Tyler, do not underestimate the brakes needed. if you had a half ton, I have a solution, however the 1 Ton and larger requires serious suspension parts. A M2 is not an answer.
