| | | Forums66 Topics128,277 Posts1,058,456 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58002 03/20/2006 12:35 AM | Joined: Nov 2002 Posts: 2,783 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,783 | Red58 is right on the money. One other possibility: is the vehicle blowing black smoke after it warms up?
Carburetor icing is a result of the "heat of vaporization" of changing gasoline from the liquid state to the gasous state. This is an endotheric change (it requires heat). The required heat is removed from the air thus cooling the air (and creating frost deposits). If the carburetor is too rich, it requires more heat to vaporize the fuel, and contributes to the icing problem.
Other than the solution suggested by red58, another possible solution is to install a air deflector in front of the carburetor to keep air from the fan being blown on the carb. Lots of imports in the early 1970's had an air cleaner with switch that allowed pulling either fresh air or heated air into the engine.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | |
Entire Thread
carb freezin-heat riser fixed, what now
| rustednuts | 03/19/2006 5:13 AM |
Re: carb freezin-heat riser fixed, what now
| truckernix | 03/19/2006 5:20 AM |
| rustednuts | 03/19/2006 5:31 AM |
| Wrenchbender Ret. | 03/19/2006 4:53 PM |
| rustednuts | 03/19/2006 6:13 PM |
| Wrenchbender Ret. | 03/19/2006 6:25 PM |
| 64fleetside | 03/19/2006 6:37 PM |
| Flxible | 03/19/2006 7:01 PM |
| rustednuts | 03/19/2006 11:25 PM |
| carbking | 03/20/2006 12:35 AM |
| rustednuts | 03/20/2006 1:15 AM |
| Flxible | 03/20/2006 2:20 AM |
| resto44 | 03/20/2006 10:54 PM | |
