0 members (),
135
3
Mod | | | Forums66 Topics128,089 Posts1,056,440 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Not a good idea to remove a couples of leafs , you'll be bottoming out the front suspension on every bump you hit. You can go with the mono leaf front spring. It lowers the truck without loosing suspension travel. Also use a dropped axle. There aren't any dropped spindles for your stock truck axle. | | |
