| | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Yes, if the dist is turning the cam is too. Have you checked the valve clearance? If the valves are too tight it won't start because of low compression. Also put new spark plugs in it, I had to do that to mine and it only sat a month. Also you might want to rebuild the carb as it is probably plugged up from sitting so long.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | |
Entire Thread
1942 Chevy truck, timing questions
| IWL BCNU | 04/17/2002 8:36 PM |
Re: 1942 Chevy truck, timing questions
| 4ontheFloor | 04/17/2002 9:53 PM |
| IWL BCNU | 04/18/2002 1:02 PM |
| 4ontheFloor | 04/18/2002 7:12 PM |
| IWL BCNU | 04/18/2002 8:16 PM |
| 4ontheFloor | 04/18/2002 9:37 PM |
| Tony | 04/18/2002 10:15 PM |
| IWL BCNU | 04/19/2002 1:03 PM |
| chris42pu | 04/19/2002 3:21 PM |
| IWL BCNU | 04/19/2002 4:33 PM |
| 4ontheFloor | 04/19/2002 4:43 PM |
| 4ontheFloor | 04/19/2002 4:46 PM |
| IWL BCNU | 04/19/2002 6:02 PM |
| Dusty | 04/19/2002 9:30 PM |
| Mechainiac | 04/19/2002 10:09 PM |
| IWL BCNU | 04/20/2002 4:22 AM |
| IWL BCNU | 04/20/2002 11:44 AM | |
