| | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | Hey jreal! Welcome to the bolt and the wealth of knowledge and advice that is contained in it's internet walls!
The harmonic balancer is pressed on. You have the puller and are using it right. Put you vehicle in gear so that you have the weight of the vehicle to help hold the engine in place. Otherwise you will just spin the engine like you said you were doing. Wouldn't hurt to spray some kind of penetrant onto/into the pully either. Try WD40 or PB Blaster, I have had good luck with those. Good luck, and let us know how it turned out!
Benjamin
58' 3200 235 3-speed/OD
