7 members (Hush, moparguy, Gdads51, Gray_Ghost, Bill Hanlon, Hugh63c10, 1 invisible),
208
0
Mod | | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I needed a little more tension so I put one end of store bought spring through the cotter pin hole in the throttle rod at the bell crank and the other around the block drain petcock | | |
