0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 49 | Just curious where the spring goes that returns the rod the joins the gas pedal to the carb goes. One end to the rod but not sure where the other end goes.
This is the spring that returns it to idle when the foot is taken off the gas pedal.
Thanks | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | In the AD trucks, the rod to the carb and the rod that goes to the gas pedal attach to a plate that pivots. A spring goes from a hole in the pivot plate to a bracket that is mounted on the lip of the pan with one of the pan bolts. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | That's the way I did mine. I just fabed a flat tab with a hole for the spring and the pan bolt. Bolt it on the pan and hook up your spring. Some will just hook it on the lip of the pan, but I didn't like this approach. It's much more secure if you have something to hook the spring on. George | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I just used a hardware store corner iron (or corner brace). Alreaday had 2 holes in it and was about the right size.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Mar 2009 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 49 | | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I needed a little more tension so I put one end of store bought spring through the cotter pin hole in the throttle rod at the bell crank and the other around the block drain petcock | | |
