| | | Forums66 Topics128,035 Posts1,055,445 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56321 02/10/2006 10:57 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If this is one of the older sixes you can probably turn the engine by hand. I will tighten the fan belt and use the fan for leverage, even with the plugs in. Just be sure to loosen the belt before driving.
Unless you are using a leak-down tester, you need to turn the engine with the starter to do the compression test.
Fred 52 3600 69 C-10
