5 members (Gdads51, Woodcmiami, 3800GUY, Bill Hanlon, chevy51truck), 156 guests, and 2 robots.
Topics128,036
Posts1,055,458
Members48,422
#56320 02/10/2006 10:02 PM
I've looked all over for a tool to manually turn a crankshaft (I'm getting ready to test compression) and I can't find one. I've never done this before; am I missing something? Anything I need to know other than taking out all the plugs first?
Thanks again,
jay
Your lack of preparation is not my emergency
#56321 02/10/2006 10:57 PM
If this is one of the older sixes you can probably turn the engine by hand. I will tighten the fan belt and use the fan for leverage, even with the plugs in. Just be sure to loosen the belt before driving.
Unless you are using a leak-down tester, you need to turn the engine with the starter to do the compression test.
Fred
52 3600
69 C-10
#56322 02/10/2006 11:11 PM
Would be much easier to have a way to crank the engine from outside the truck. You should have a remote start switch or if you still have a floor starter, just get a giant screw driver and manually engage the starter. BE SAFE!!!
1946 1/2-Ton Chevy
