| | | Forums66 Topics128,041 Posts1,055,490 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56256 02/09/2006 9:45 PM | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | You may want check this site: http://groups.msn.com/SplitWindowRestorations/steeringboxphotos.msnw (Or do a search for Split Window Restorations on the web.) It is a site run by Robert Atkins here in Portland and he has in his pictures how he did the pittman arm in a V8 conversion. If I remember correctly he had the arm cut and welded to change the lower ball to go to the inside rather than the outside to create the offset. Good Luck Steve O | | |
